Write Rapid Data (boolean)
Dear all,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I have problem to set a rapid boolean. image
To get the actual value of the rapid boolean is working, but I can't write a new value.
Should this working with the FillFromBool() Methode?
Can anyone send a code example?
Thanks
Best regards
Roland
  • Hi Roland
    This works for me
    private void WriteBool(string task,string module,string variable,bool WriteValue)
    RapidData GTPUAppRunning=
    null;
    try
    //Write true to RAPID variable bGTPUAppRun
    GTPUAppRunning=abbCtrl.Rapid.GetTask(task).GetModule(module).GetRapidData(variable);
    IRapidData Value;
    Value=GTPUAppRunning.Value;
    Bool retValue=(Bool) Value;
    retValue.FillFromString(WriteValue.ToString());
    GTPUAppRunning.Value=retValue;
    catch(Exception ex)
    //Do exception handling
    GTPUMessageBox.Show(
    this,null,ex.Message);
    Per Svensson
    Company Specialist
    ABB Automation Technology Products
  • Is there any reasons to cast the bool to a string and parse it to Bool via the FillFromString method?
    Shouldn't :
    GTPUAppRunning.Value = new Bool(WriteValue);
    bee enough?
    Please bear with mee - i'm new to this API.
    Best regards
    JJ
