Event Manager / Smart Components
I used to have my tool change operations handled by Event Manager, all the settings are still there in 5.13, but it just doesn't seem to work anymore.
So I thought I would try out the new smart components. When I add an attacher component I I cant select a flange, so I cant really continue any more. I want to attach/detach the tool from the robot, can someone give me a suggestion how to do this?
Thanks
Select the robot as Parent and press Apply, then you should be able to select the flange.
regards,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0 -
right that works .. a bit backwards but hey....thanks0
- 87 OmniCore
- 40 AppStudio
