'Object is part of a project' debug error
Kevin
When running my add-in I get the error message 'ArgumentException is unhandled: Object is part of a project' in the Visual C# debugger when
[CODE]myPart.Bodies.Add(myWire);[/CODE] executes.
Can anyone explain what this message means?
Thanks,
Kevin
Thanks,
Kevin
An object cannot have two parents. You must make sure myWire is "orphaned" before you add it to a part.
BTW, API questions should go in the "Developer Tools" forum.
Johannes Weiman2010-05-07 10:55:53Johannes Weiman
Software Engineer
ABB Robotics0 -
Thanks Johannes.
Kevin
