RobotStudio Performance
Thomas J
Applied your "fix" for performance issues, it does not happen as often now, but still does -
when all is ok, it takes a second or two. When the problem happens - it takes over 5 minutes sometimes!
Best thing to do is be patient - I used to KILL the rs process and start over, but when you do, you loose all your work from the last time you backed up or saved the RAPID. Also - if the VC does not terminate correctly, the next time you start you find the previous sessions work is completely gone, starting with what you had the last time the VC was opened...
Check program started: All tasks in system GL50. 5/16/2010 2:11:46 PM RAPID
Checked GL50. 0 syntax errors, 0 semantic errors. 5/16/2010 2:16:48 PM RAPID
Check program started: All tasks in system GL50. 5/16/2010 2:37:05 PM RAPID
Checked GL50. 0 syntax errors, 1 semantic errors. 5/16/2010 2:38:46 PM RAPID
Check program started: All tasks in system GL50. 5/16/2010 3:01:07 PM RAPID
Checked GL50. 0 syntax errors, 0 semantic errors. 5/16/2010 3:06:48 PM RAPID
Thomas H. Johnston
PACs Application Engineer
We deeply regret this problem and are very sorry for the inconvenience caused.Henrik Berlin
ABB0
