How to simulate an input digital signal button in
lister
in ScreenMaker
How to simulate an input digital signal in RS5.13 screen maker?
BR
Moved to ScreenMaker forumHenrik Berlin
ABB0 -
Hello,Signals values can be set, reset, pulsed, inverted, read or written.Signals can also be bound to properties of the controls.Signals have to be created from RobotStudio Offline or Online tab which can be used in ScreenMaker.Hope, this information is helpful.If not, you can share your thoughts on what is your use case of the application being developed.Thanks0
If there are no good idear ,I can only use cross connection
- 364 IRC5
- 83 OmniCore
- 37 AppStudio
