External Axis Value Copying...
paul_gkn
Does anyone know how to read the position of an external axis then copy the value to another target whilst adding a given value to the copied value?
I have several hundred targets all with slighty different external axis values and need to move a common target after each. The common target needs to position the external axis 45 degrees from the last point. I want to keep my logic code as short as possible so ideally i'd like to find a away to read the external axis value, add 45 degrees to it, then apply this value to the preprogrammed common point. Any ideas?
Hope this makes sense!
Thanks,
Paul.
I have done similiar things in rapid withactpos := CRobt();newpos.extax.eax_a := actpos.extax.eax_a + 25;but if you require it to be exact then you need to make sure the robot is stopped or have a fine point before you use Crobt.0
Thanks Matt,I've tried something similar but the pause at CRobt() was unacceptable.I've got something from ABB UK that I think might work.Cheers...0
