Smart Component - signal to property
Laro88
How to work with signals and properties in smart components?
I have a smart component that I would like to bind to an analog output - and use the value in my smart component.
To do this I create an analog input signal which I can bind to an analog output in the robot system.
The problem is that I can't find a way to link "analog input signal" to "property" - feels like there is a ABB smart component missing that can glue these together.
Any suggestion on how to do this?
The Converter base component is meant to do exactly this. Have you tried it?Henrik Berlin
ABB0 -
I missed that one completely - will try it out asap.
I have been trying all sorts of crazy stuff - except the most obvious one :-)
Thank you very much
