Problems with DigitalSignal Set method
I am attempting to use the Set method of the DigitalSignal class in the 5.06 PC RAB SDK.  I have no problems reading the signal's value and I have no problems using the Reset method.  However, the Set method fails to turn on the digital output that I am subscribing to.  When I call the Set method no errors are thrown.
Is this a known bug?  If so, when will we see a fix?
Bryan Johnson
bryan.johnson@wolfrobotics.com
Wolf Robotics
4600 Innovation Dr.
Fort Collins, CO 80525
USA
  • This problem was found on real and virtual controllers running 5.06.0085 and 5.06.0095.  PC SDK is the 5.06 beta version issued this week.
    Bryan Johnson
    Wolf Robotics
    4600 Innovation Dr.
    USA
  • One more piece of information...
    My IO signals are defined with the following access level:
    EIO_ACCESS:
          -Name "MY_ACCESS" -Rapid -LocalManual  -LocalAuto -RemoteManual  -RemoteAuto
    Bryan Johnson
    Wolf Robotics
    4600 Innovation Dr.
    USA
