could anyone help me
Hi everybod;
I'm beginner in RAB
I need someone to tell me where should I write the code in steps 7 & 8 in page 91
in RAB application manual ( revision D Robot Ware 5.0 )
pleaaaaaaase
I need it urgently
thanks in advance
mostafa mokadem2010-06-25 16:51:22
  • Hi,
    are you coding in VB.NET or C#?
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • the problem I faced is not at this example only
    the problem is that the manual many times tell us to do some thing but not specified exactly how and where(in the code blocks)
    I faced this problem many times and the results are "errors" when I do Build
    mostafa mokadem2010-06-27 22:18:44
  • It's my Graduation project , please I need the help every short period as its due is on the next month
    thanks for your reply and waiting the explanation
    mostafa mokadem2010-06-27 22:22:41
  • Hi Mustafa,
    I'll try to help you with your urgent problem first, and then I can take a look at the examples with hard to understand descriptions.
    In the text/picture in step 6 it is described tht you should add a menu item. If you have done that you should have a member variable menuItem1. You can verify that by searching your entire solution.
    In order to get an event when the menu item is selected, you must add an event handler.
    Th most common place to do this is after the call to IntitializeComponent in the constructor of your form. But anywhere in a method that is called when your form is loaded will work.
    The easiest way to add an event handler is to simple use IntelliSense, write "menuItem1." and select "Click" from the drop down. Then write "+= " and a tooltip shall appear which asks you if you want to add the event handler.
    In the event handler you implement the action that shall happen when the menu is selected.
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • ok, that's for the event handler
    now what about these two statement , where should be written
    this._launchService.LaunchView(FpStandardView.Jogging,null,fa
    lse,out this._cookieJog)
    private ABB.Robotics.Tps.Taf.ITpsViewLaunchServices
    _launchService;private object _cookieJog;
    realllllllly thanks for your help
    mostafa mokadem2010-06-27 22:35:20
  • [QUOTE=mostafa mokadem] ok, that's for the event handler
    The above line shall be in the event handler which was created when you subscribed to menuitem1.Click += ......
    The above line declares member variables and can be written anyware outside methods but inside your class.
    [/QUOTE]
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • thankssssssssssssssssss SmileSmileSmileSmileSmilemostafa mokadem2010-06-27 23:48:15
  • in the first line there is a missing semi-colon ";"
    Am I correct ?
    thanks again for help
  • this error results
    Error    1    Cannot implicitly convert type 'bool' to 'System.EventHandler'    C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4view.cs    29    32    TpsViewIRC5App4
  • now I pressed TAB twice as mentioned & wrote this line inside the brackets
    this error results :
    Error    1    Method name expected    C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4view.cs    29    49    TpsViewIRC5App4
  • ooooooohhhhhhhhh
    now build succeeded with the two statements in this form
                menuItem1.Click += new EventHandler(menuItem1_Click);
                this._launchService.LaunchView(FpStandardView.Jogging, null, false, out    this._cookieJog);
    mostafa mokadem2010-06-28 20:37:40
  • Hi,
    since RobotStudio 5.13, RAB is included in RobotStudio.
    FlexPendant SDK and PC SDK are installed by RobtStudio.
    We have made some corrections in the application manual (Appliation Manual FlexPendant SDK). Please make sure you hae the latest version (5.13) before you continue.
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • OK,
    but before I switch to RAB 5.13
    could you help me there please
    http://forums.robotstudio.com/forum_posts.asp?TID=4220
    there in inconsistencies in RAB 5.11 examples Unhappy
