Regional options and comma separator issue.
NFC
if in your Windows O.S. regional options you have defined as decimal separator the comma (,) instead of the usual US standard dot (.), then you will have it translated also in rapid when doing sinchronization to VC.
This will result in an error like "missing parameter", in fact in Rapid the decimal separator is the dot and comma is used to separate arguments in routine calls.
I've noticed it using the "SetBrush" action instruction;
I'll post some pics:
Thank you,
Nils
As usual I made a mistake in my previous post...the thirh link is wrong, had to be this
- 40 AppStudio
