Add Devices to Import lists [Bending PowerPac]
Each device has a rslib file and a configuration file. The configuration file contains information for work object, frame and descriptions. You can open an existing device for rerence. Each device should be put a seperate folder which should have the same name as the rslib file. You should copy this device files to user application data folder. Below is the example:"C:Documents and SettingsCNXIYIN2Local SettingsApplication DataABB Industrial ITRobotics ITRobotStudioAddinsBending PowerPacDeviceLibraryGripper"0
