WebWare SDK with C# [WebWare SDK]
You should be able to do this provided you are able to import ActiveX controls and convert them into CLR compatible assemblies. In MS C# 2003, this is done automatically when you try to use an ActiveX control in design view; Visual Studio will invoke the AxImp.exe utility for you.Russell Drown0
