Sub Menu item in Commnandbar not updated
Hello People,<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I have the following problem.
When I use a menu in the command bar and disable the functionality of the menu (.enable=FALSE) the menu is disabled. I also use this functionality in a sub item of the menu item (pull down menu appears) When I enable the functionality of the menu items only the item in the command bar is updated and not the sub item. (.enable=TRUE)
Figure indicates both items are disabled.
<?: prefix = v ns = "urn:schemas-microsoft-com:vml" />
Figure indicates both items are enabled. (Note: only the item in the command bar is updated)
I?_Tll already tried update() and Refresh() but this does not solve the problem!
Thanks for the help.
Edwin Peeters
  • Sorry but I'm not sure that I understand your problem....Can you please share the part of your code that enables/disables the different menu items and point out which part of the code that doesn't work as expected.
    Lennart H
  • Thanks for the quick response,
    If the robot is in automode it has to disable the menu's, when it is in manual mode the 2 items must be enabled. The problem is that only the item in the commandbar (Tool) is enabled and the item (Stocklin I/O) stay's disabled. Note: When I close the subitem (System) and open it again it is also enabeled!
    Here it is :
    If soAutoOn.Value = 1 Then
    ' Robot in automatic mode
    Me.Menu_Tool.Enabled = False
    Me.Menu_Stocklin.Enabled = False
    Else
    ' Robot in manual mode
    Me.Menu_Tool.Enabled = True
    Me.Menu_Stocklin.Enabled = True
    End If
    Greetings,
  • Hi ... are you running this code while the subitems list is opened?
    Carlos Martinez
    ABB
  • Yes Carlos, you are right, when I close and open it again it's enabled.
    Greetings,
    Edwin
  • Hi again,
    The Enable property of the MenuItem forces to repaint its container only when it belongs to a CommandBar (consistent with the Menu_Tool). But, in the case of Menu_Stocklin, this MenuItem is attached to a MenuItem, not a CommandBar
    The  UI which displays the list of submenu only paints itself after it is opened and after you click on it. Maybe, as a work around, you could close the SubMenu and let the operator open it again (if needed).
    BR
    Carlos Martinez
    ABB
  • Small comment, not sure if it's relevant or not Smile
    I follow your logic using C# and FlexPendant SDK 5.13 and the menu closes if it's open when I run the code below.
    private void cmdBoth_Click(object sender, EventArgs e)
                if (menuItem3.Enabled == true && menuItem1.Enabled == true)
                    menuItem3.Enabled = false;
                    menuItem1.Enabled = false;
                else
                    menuItem3.Enabled = true;
                    menuItem1.Enabled = true;
    Niklas Skoglund2010-09-23 08:38:46
    Lennart H
