How to manage a variable?
oscar_f
in ScreenMaker
I'd like to manage a variable in SM.
For example,
image to have a rapid num Speed:=10.
I'd like to push a button and icrease this value,
for example by 5.
then if the Speed reach 100, I'd like to reset this value to 0.
How can I do this?
(Call .net method? how to pass the current value to the method?)
Can I have an example?
BR
Oscar
BR
Oscar Ferrrato
Oscar Ferrrato
Hello,You can refer to ScreenMaker chapter in RobotStudio 5.13 Help documentationSearch for the keyword 'Call .NET Method' in search tab.Steps are defined describing usage of Call .Net Method.I have attached a project which would help you out. The return value of the your method would be the value being passed as paramter. Bind the value to an application variable.Thanks0
Thank you for the example.Now I'll take a look on it.Just a comment, I cannot find anythink about .net Method in RS 5.13.1 help on lineOscarBR
Oscar Ferrrato0 -
Thanks.I did it work. I forgot to write again my rapid variable after the method code.(about the manual- I find the content, the problem was that the help search it was not working. I find it searching it manually...)BR
Oscar Ferrrato0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 29 AppStudio
