Req. New Feature: Quick deploy
oscar_f
in ScreenMaker
Hello
I'm a lazy guy,
and when I started to use SM I immediatly got bored during the debugging:
there were a lots of steps to do manually each time I made a modification...
why do not add a new button in the ribbon : "Quick Deploy" which will do:
1)Close FlexPendant (if it is running)
2)Save SM project
3)Build new solution
4)Deploy new solution
5)Restart FlexPendant
BR
Oscar Ferrrato
Oscar Ferrrato
This information may be helpful to you:1. Build will save the project if not already saved. So step 2 is not mandatory always to be carried out.2. When deploying check is made of Virtual FlexPendant is running and can be closed during deploy. So step 1 is not mandatory always to be carried out.3. Restart FlexPendant after deploy would not be always the right solution because we would be dealing with both real and virtual flexpendants. There may be a risk invloved. Its more applicable while working with virtual flexpendant.Thanks0 -
So,it is necessary to :1)Build2)deploy3)restart Virtual FlexPendantIt is possible to recognize if the controller is virtual and then start virtual FP...BR
Oscar Ferrrato0 -
Hello Oscar,That is correct. Thanks for the input.0
- 858 RAPID Programming
