Repair installation after upgrade
Niklas Skoglund
Users that are upgrading to FlexPendant SDK 5.13.02 from FlexPendant SDK 5.13 or 5.13.01 (using the RobotStudio installer) are recommended to perform an installation Repair directly after the installation has completed. The reason is that two files required for FlexPendant SDK and ScreenMaker will be missing otherwise (ABBct.exe and ABBct.exe.config). This is not needed if performing a so-called clean installation where no previous version of RobotStudio 5.13 is installed on the computer.
We are sorry for the inconvenience caused. The limitation will be resolved in the next release of RobotStudio/DeveloperTools.
