Launch RobotWareArc View from custom Application
I tried to launch the "RobotWareArc GUI" from my custom application , but it doesnA't work.
private void btnRobotWareArc_Click(object sender, EventArgs e)
try
if (iTpsSite.LaunchView("TpsViewArc.dll", "ABB.Robotics.Processes.Arc.ArcViewDesktop", null, true, out _cookieD) != true)
GTPUMessageBox.Show(this, null, "Could not start User application");
return;
catch (Exception ex)
GTPUMessageBox.Show(this, null, ex.ToString());
According to the SDK Reference Guide it should be possible , maybe i do something wrong.
Has someone done this before ?
This is my code :
try
return;
HiI'm a bit confused...Can you please tell me:-In which manual did you find this?-Which is the version of the manual?-In which section/page did you find this.Thanks!Lennart H0
This can be found in the "FlexPendant SDK Reference guide" located at C:Program FilesABB Industrial ITRobotics ITSDKFlexPendant SDK 5.13Search for => ITpsViewLaunchServices.LaunchView methodIt now works , i was missing some code in the ITpsViewSetup.Install method.0
