Load System from RobotStudio
mattz
When I try and load a system from robotstudio to the robot controller I get an error stating that "There is not enough disk space on the remote host". I tried to clean up the disk space but I cannot delete any more data. I have loaded other systems to other robot controllers but this one seems to be giving me a hard time. Any help would be greatly appreciated.
Thanks,
Matt
Do you have any other installed system on your controller?
Erdem Karaçeper0 -
Perhaps you should do an X-start to bring up your controller in boot-server mode. From the FlexPendant you can check which systems that are available on your controller and delete the unused ones. You can download your new system to the controller from RobotStudio when the controller is in boot-server mode.
Note: It is recommended to keep your last used system (that you are upgrading from) until your new (upgraded) system is up and running. Also, remember to do a backup of your old system before upgrading. You will need to restore the backup into the upgraded system to preserve your data.Henrik Berlin
ABB0 -
I deleted the system from x-start and was able to load a new one. Thank you very much for the info.
Matt0
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
