Generic MyGetRapidData<T>(ControllerInfo,VarName)
Thomas J
Example how to use generics for retreiving rapid data in C# - Example written for VSTA in RobotStudio API
Thomas J2010-12-01 02:31:18
pre-requisite - ControllerInfo set against a virtual controller. = cinfo
will return the fisrt found or a default of the type if not found or an exception.
Example Usage:
bool bVar1= MyGetRapidData<Bool>(cinfo, "bSomeVariableNameA").Value;
double dNum1 = MyGetRapidData<Num>(cinfo, "nSomeVariableName1").Value / 1000.0;
RobTarget r = MyGetRapidData<RobTarget>(cinfo, "p10");
//Generic to get RapidData() structure
private T MyGetRapidData<T>(ControllerInfo ci, string stVariableName)
T objectToReturn = default(T);
if (ci == null)
Logger.AddMessage(new LogMessage("ContollerInfo Parameter=NULL!", LogMessageSeverity.Warning));
return objectToReturn;
using (Controller controller = ControllerFactory.CreateFrom(ci))
RapidSymbolSearchProperties sProp = RapidSymbolSearchProperties.CreateDefaultForData(true);
Task[] tasks = controller.Rapid.GetTasks();
foreach (Task task in tasks)
using (task)
RapidSymbol[] datas = task.SearchRapidSymbol(sProp, "^" + stVariableName + ".*");
if (datas.GetLength(0) > 0)
using (RapidData rapidData = new RapidData(controller, datas[0]))
tasks = null;
try { objectToReturn = (T)rapidData.Value; }
catch (Exception ohoh) { Logger.AddMessage(new LogMessage("GetRapidData<T> (...) " + ohoh.Message, LogMessageSeverity.Error)); }
if (ci == null)
using (task)
tasks = null;
Logger.AddMessage(new LogMessage("Could not find " + stVariableName, LogMessageSeverity.Warning));
Maybe someone can clean it up - im new to c# - and may have broken some basic rules here - but it seems to work.
Thomas H. Johnston
PACs Application Engineer
