Interlink Trouble
I use WebWare interlink 4.5 ,my interlink is always in the connectting state,Why?
I found that in the local area connection properties I only see the output but onne input.It seems that I can't get anything from robot controller.
My RobotWare is 5.05,My Robot is IRC5 M2004.WinXp Pro Sp2,I Also test the Interlink 4,I got the same result.
Can you tell me Why?
Nick38599,568287037
  • Hi!
    got the same problemes here - seems to be our firewall / the security policies on our machines. I made it working by using a second networkcard (which seems to be handled in another way by the system). if you can ping the robot, the connection should work (technically).
    greets
    M (DC-Ag)
    01000111
