the task frames in the MultiMove system
Hi ,
    I have built a MultiMove system with two robots in RobotStudio, everything worked fine except that when I save the station as a pack and go and open it again, I can't run the simulation again, instead it shows an error saying that "Power fail restart failed".
    I found that if I set the task frames for the robots to the current values , and then reconfigure the targets in the robots paths, it will run the simulation correctly, but ones I save the station and open it again, I got the same error.
I hope that someone could help me with that.
Thanks,
/Abood
  • Please get in touch with your local ABB Robotics Service representative that can forward your issue to our tech support.
    ABB
  • Thanks a lot for the respond, actually I managed to find the problem and solve it.
    Regards,
    /Abood
  • would bee nice to know how you solved it
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
