S4Backup [WebWare SDK]
I have a problem.
What shoul I do to have this backup done in my pc ?
I wonder if someone could help me with the backup method.
When I use something like this :
dia = Format(Date, "ddmmyy")
NombreFichero = dia
status = FrmBG.robotHelper.S4Backup(NombreFichero, 3, resultid)
If status <> 0 Then ' did the function work?
Error_msg status, ""
Exit Sub
End If
then I get the error -5108 General error for log
I want to use s4backup method only works on the local memory device and then to be copied in PC with S4FileCopy.But not work. What happen?
1.Which WebWare SDK build version, for instance 3.02.0317, is in use?
Webware SDK Release 3.2
2. Are you using long file names on the robot (longer than 8+3 characters) ?file name=140905
3. What are your settings for the following Interlink Configuration properties:
a. Alias name = R_1994
b. TCP/IP node and IP address =localhost
c. Profile name =R_1994
4. Describe the configuration of robot, i.e. BaseWare version, software options, robot type, etc.
BaseWare 512Robot type= IRB 4400
FactoryWare, Ethernet FTP, English, Multitasking, Advanced Function, Profibus DP Master/Slave
