Picking from a tracked conveyor.
Lowe1
Hello All,
I have been working with understanding the Smart Components and Conveyor tracking recently and I am not able to pick up an item off of a conveyor being tracked. Is this a limitation? If not, how can I add more parts to the tracked conveyor. I do not believe this is a common application but I just want to know RS limitations.
Thank you for your help.
Hi,You can not attach/detach objects when you use conveyor tracking (workobject moved by the conveyor) in RobotStudio.Best regards,
ABB Robotics0
- 361 IRC5
- 77 OmniCore
- 852 RAPID Programming
- 30 AppStudio
