Smart Component Attacher\ Detacher
Is is possible to make the SC Attacher Detacher child to "find closest object any object"? Just like you can in the event manager?
Yes, if you use the "Attacher" and "Detacher" in combination with the base component "ClosestObject". See the attached example station.
ABB Robotics0 -
Sweet, now it is so obvious
Tanx0 -
Well, I get it all to work when doing it manual, like in the example, but when I want to simulate it, the closest part (child) becomes the robot, not the actual part I want to attach.All the I/O connections are correct, and they are indicated correctly in the I/O-Simulator..I'm total newbee in RS, so I may have made some fatal setup errors or something... hehe
To avoid that the robot is the closest object you ca try to change the property "ReferencePoint".But I recommend that you use a line or plane sensor instead of "ClosestObject".Best regards,
ABB Robotics0 -
Got it now, I used plane sensor like you said...tnx0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
- 107 Collaborative Robots
