switch from manual to manual full speed mode
Berndl
where can i change the speed configuration (here 3% when i change from manual mode to manual full speed mode), because i will 100% when i go to full speed mode.
Thats why they call it full speed mode, i think.0
Interested in a workaround?Create a eventroutine connected with the START event, for example:PROC rEventStart()! Event StartIF OpMode()=OP_MAN_TEST AND CSpeedOverriede (CTask)=3 THEN! full speed override 100 if override was 3SpeedRefresh 100;ENDIFENDPROC--> This solution with SpeedRefresh does not work, because SpeedRefresh only allows smaller values than the actual value on the Flexpendant. The SpeedRefresh will not be displayed on the Flexpendant override.Best regardsMarcel2011-05-19 12:40:140
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
