Load geometry
dsk-lm
Is there any way I can make RobotStudio remember not to load the geometry for specific libraries? If not, is there any way I can "unload" geometry for a library that has already been loaded?
I have tried to setup a station where I unchecked the "load geometry" checkbox when importing libraries. But the next time I start the station the geometry is loaded.0
If you load a station with the "Load Geomeotry" check box UNCHECKED, then Save or SaveAs a new file name (if you do not want to loose the original geometry) and you will get a warning, explaining that the geomoetry will be lost when saving...Click YES - then the next time you open that station, the geomotry will not be loaded, because it was saved without geometry loaded.Thomas J2011-02-09 17:09:07Thomas H. Johnston
PACs Application Engineer0 -
If you want to be more selective, you can "Disconnect" your library, right-click it in the browser, and select "Remove Geometry", then "Save As Library" again.Henrik Berlin
ABB0
- 5.5K RobotStudio
- 398 UpFeed
- 19 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 324 IRC5
- 63 OmniCore
- 813 RAPID Programming
- 6 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
