I/O singnal
amindari
i'm using ABB-1400...and i want to write a rapid program to control a system,how can write a rapid program to control a digital input ?
Check the manual "Introduction to RAPID" that is available in RobotStudio.Henrik Berlin
ABB0 -
thanks for your reply henrik..i'm confused with unit mapping when creat a signal,i want to add a digital input in i/o board ,in label x4:1 .and confused with setting the unit mapping value .how can i set this data0
i fixed the problem .thank you anyway
- 40 AppStudio
