Adding new robot models
How do I add new robot models to RS? I have put the new IRB760 rslib file in the folder but do not have a template file so cannot create a station from template.
Andrew Goddard
Hi,First create a system with System Builder.Then open an empty RS station and add existing robot system.RS will now ask you for the robot model.BR / HenrikKga Offline Center www.kgaofflinecenter.se
Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac0 -
Hi Henrik
I have tried to follow the instructions.
I have created a system with virtual key and have selected 'addional motors or no IRB manipulator' as selecting anything else brings the selected manipulator into the station.
I then selected 'new station' and selected 'existing system' and selected my saved empty station with the system I configured.
The virtual controller starts however I am not prompted to select a robot model.
I have tried importing the library file however the manipulator does not link to the virtual controller.
Am I missing something?
Thanks
Andrew
Andrew Goddard0 -
webwiz/3754/system.rarHello Andrew,I am no expert in IRB760 but I have done tests like this before with other robots.I did a small test and RS asked me for the robot model.I send you the xml option list that I tested.I am not sure if it is okay but you can try.BR / HenrikKga Offline Center www.kgaofflinecenter.se
Hi Henrik
I have sorted it. I had the wrong version of RobotWare. You need 5.13.03 which has the IRB460 and IRB760 to select in the manipulator list.
Thanks
Andrew Goddard0 -
Perfect!BR / HenrikKga Offline Center www.kgaofflinecenter.se
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
