Config Edit and S4C+ EIO.cfg Files
Thomas J
Does config edit support the creation and editing of eio configuration files that contain bus definitions for CAN 2 ? I have tried to load the following using config edit to edit them, but with no succcess. Also if you try to create a new configuration file, the options for CAN2 never become available (stay greyed out) - so is it possible to configure an eio configuration file using CAN2 bus? - options included IOPlus.
Thomas H. Johnston
PACs Application Engineer
