pc sdk starting problems?
djperala
webwiz/3886/ABBPCSDK_test.rarHello
I am new to using PC SDK and have a slight issue someone might be able to explain to me.
I have been given a program that works perfectly on microsoft xp using visual studio 2008.
I have windows 7 x64 and visual studio 2008.
What happens is when the program runs it comes up with
Warning 1 'ABB.Robotics.Controllers.Discovery.NetworkWatcherEventHandler' is obsolete. C:UsersDanielDocumentsVisual Studio 2008ProjectsWindowsApplication2WindowsApplication2Form1.vb 76 23 WindowsApplication2"
and wont run any part of for "Private Sub Form1_Load"
ill upload the program, anyone know what the problem is and how to fix this.
i am desperate to fix this asap
I think you need to change your target platform from "Any CPU" to x86.
Kind regards
Daniel
cheers mate,yes this fixed the problem.it took me a while to figure out where to change this setting but once found it worked.0
Hehe, been there done that. Your welcome!Oh, might aswell tell you since your using a 64-bit OS. There are some other problems within the ABB libraries. Some libraries can not handle file paths with brackets. so "C:Program Files (x86)" can be a bad idea.I think this issue will be fixed in the next release thoguh!Kind regardsDaniel CarlAcn2011-03-22 08:13:46//Daniel0 -
If you end up compiling to .NET 4.0 at some point in time, then you will also run into problems, some are described in this fine forum.
I have ended up using pure 3.5 code until the abb libraries are 4.0 safe.
- 40 AppStudio
