How get a new Frame with a Pose?
Jorge
Hello, I calculate the a Pose, with DefDFrame, Then I use PdistSe, and the robot move to the correct position.
But who can I get a new Work Object, with the Pose?
Thanks
/Jorge
Thanks
/Jorge
Jorge Turiel
Hi JorgeI assume you want to use your Pose values in the wobjdata? You can do it like this:wobj1.uframe:=pose1;If you want your pose values to object frame instead, then you should change uframe to oframe.I hope this helps you!-Osku0
