Module name åäö!!
DaveR
Hi!
I have a question about the syntax when you give names to your program modules!
In Robotstudio the letter "A-" works fine(example SA-KNING.MOD), but when I load the module on the "real" robot, the robot accept it without any errors, but i cant modify anything in the module!
If I then change the name to SOKNING.MOD, everythings works fine in the real robot i can modify and do my changes and everthing works fine!
My questions is: Should I be worry about the I/O,Procedure and Robtarget syntax as well, because i use the letter "A?" there also but without any (for now) errors?
BR DaveR (SWE)
