Process Time Calculation
Dear Sir,
I have completed simulation on an industrial component on robotstudio. Now I want to optimize the cycle time. How can I vary process time with variation of speed. Please Guide me.
Thanks.
Regards,
VASUDEVA
  • Dear Vasudeva
            This is the program example of how to calculate the cycle time :
    MODULE MainModule
    VAR clock clk1
    VAR num clk01
    PROC main( )
            rResetClk;
            rStartClk;
            ........ (robot movement on 1 cycle)
            rStopClk;
            rShowClkTime;
    Local PROC rResetClk ( )
            clk Reset clk1;
    Local PROC rStopClk ( )
            clk Stop clk1;
    Local PROC rStartClk ( )
            clk Start clk1;
    Local PROC rShowClkTime ( )
            clk01 := clk Read (clk1);
            TPWrite "Cycle Time Robot is = "
    um := clk01;
            I hope this will help
    BR
    Dhyan W
    fear of GOD is the beginning of wisdom
  • I have tried various ways to calculate time with robostudio for my pallet wrapper equipment. But no luck with it. I need someone to help me here, please. allanjames2011-06-28 14:32:11
  • To make it virtual, you will need to make a virtual controller.  The other commenter seems to think you already have a VC setup, or you are running on active equipment.  But the way you are writing, it sounds to me like you are not running any active process.  As to how to set up a VC, I don't remember.  There are guides available on google, but not the most straight forward.
