Status Light of Panelboard
After getting several messages regarding the status of the panelboard. I check the status light and it is red. Looking at a robot that is working I see that the status light is green. I have a spare controller that is not in production. Could I swap out the panelboards in the robots with out causing any issues? they are both IRB 2400 with Dual IRC5 cabinets
Hi,Check the part numbers on each of the panel boards, if they are the same then there is no problem with swapping them.RegardsGraeme0
- 38 AppStudio
