PC SDK
than
How to use the PC SDK in manual mode,it is possible to avoid "remote write access in Manual mode" on the FPU ?Thomas Gerth Andersen
Hi than,have you requested masterhip from PC SDK, in your scenario?Do you want to know if you can avoid the question on the FlexPendant wher you need to say that it is OK for the other client (your PC SDK application in this case), to take mastership?From PC SDK Application Manual:Manual and automatic mode
When the controller is in manual mode, the FlexPendant has priority to write access.
Mastership will not be given to a remote client unless an operator explicitly allows this
through the FlexPendant. At any time, the operator can clickRevoke on the FlexPendant to
get the write access back.
In automatic mode, the client who first requests write access will get it. If a remote client has
taken mastership of a domain other remote clients will not be allowed write access, but will
get an exception if they try. For the operator, there is no way to revoke mastership to the
FlexPendant, but to switch the operating mode of the controller to manual.
As for a remote client, such as a PC SDK application, however, mastership handling has to
be carefully implemented by the application programmer.
Hi Nikals
Yes i have mastership over the controller, works fine in auto.
It is to a sensor input, from a 2D camera, it is not OK, when will modpos i manual,
it is old code from S4, which worked fine with a serial port.
Have tryed with ABB optical tracking option, without luck.
I will test sensor interface over TCP / IP,if I can find some documentation
Thomas
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
