Create Positioner
robolab
I have Problems with an Non-ABB Positioner.
I create the Kinematic as an External Axis. At this Positioner there are 2 Wobj moved by the Kinematic. My Problem is, that the TCP Data from my Weldgun is not the same in the Station and in the Virtuell Controller. I try many different Values in the Systemkonfiguration but I dont find the reason.
Can someone help me.
Do you use configuration files that match the positioner? Is it a one axis or two axes positioner?Henrik Berlin
ABB0
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
