RobotStudio Bending PowerPac 5.14 is released [Bending PowerPac]
Improvements in Bending PowerPac<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
1)     BPP version information is saved in RAPID program
2)     RAPID template is open to user
3)     A trial license for BPP is provided under the installation folder
1)     In bending operation definition window, the piece orientation is always enabled; In previous version it will be set automatically.
2)     Fixed the problem in BendWare about palletizing which might cause wrong piece orientation(Bug 12408)
3)   Incorrect inside/outside setting when designing a gripper
4)     Wrong offset value in the call of MoveOut(Bug 13197)
5)     Incorrect gripper orientation during palletizing simulation(Bug 13305)
6)     Punch/die placement problem(Bug 14190)
7)     If more than one VCs are available in same PC, BPP might connect to wrong VC(Bug 14209)
8)     The robot target in the instruction of ?_oTrackFromPinch?__ is wrong and robot can never move from current position to this target(Bug 14291)
9)     Fixed the problem about the status of ?_oAfterBend?__ which never changes to green(Bug 14305)
10)   Speed setting is opposite during palletizing simulation(Bug 14309)
11)   Vacuum cup can?_Tt be selected after loading a tilter from a rslib file(Bug 14313)
12)   Exception is thrown when creating a new gripper(Bug 14312)
13)   TRE doesn?_Tt take effect when restoring targets for first time(Bug 14325)
1)     When preview palletizing in bending mode for second time, old pieces cannot be removed
Please find the dowload from the link below.
http://www.abb.com/product/ap/seitp327/049ffeb82687791ec12574b9004958cf.aspx
