Error Eventmanager
After Upgrade to RS 5.14 all my events in eventmanager runs 2 times. First very slow and then as wanted in transition time.
I'm using the cell showen in http://www.youtube.com/watch?v=gnks-xjI2GI
Now i have made a small test cell and it do the same.
 see video.
[TUBE]Q8_zI_Pmj84[/TUBE]
Pack&Go off my test cell
Is it a Bug or do i miss some new settings in RS 5.14.
I need to show it on fridag.
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus
    If the robot is moving in cycle the simulation looks fine.
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Klaus
    Klaus ✭✭
    Yes but it should still work in manual when i trick my output in IO simulation. IT worked in 5.13.
    I have now find put that if trasition time is set to 0 sec. in my mecanishme it works fine but if time is 0.1 sec it runs 2 times. Soo it must bee a bug in Mecanishme and not in eventmanager
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hi Klaus,
    It seems to be a bug in 5.14 when you control the mechanism with the Event Manager and the simulation is not running.
    I will report this problem.
    However, if you make a Smart Component of the mechanism it behaves correct (see the attached P&G).
    Anders S2011-05-05 17:26:52
    ABB Robotics
  • Klaus
    Klaus ✭✭
    Thanks Anders.
    I will change my 12 mechanisme to SC after my presentation tomorrow.
    Now i have set my time in my mechanism to 0.0 sec
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Klaus
    Klaus ✭✭
    Hi Anders.
    I have tried your test cell but can't see that the transition time works when i trick my output.
    I have also tried the duration time in the SC but cant see any difference.
    Do i miss something?
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Klaus
    Klaus ✭✭
    I have now add to linesensors. Linesensor_Front & Linesensor_Back.
    When i Activate my signal i manuel my cylinder runs without time transition and i get no senseout signal from linesensors even they both have activate signals.
    If i run simulation it works fine.
    Before SC i made the same in eventmanager.
    My outputsignale activate an event that run my Mecanism to pose. At end off pose i had a dummypart(sensor) and a collisiondetect. The colissionevent activatet my DI in the robotcontroller. That worked in both manual and in simulation mode.
    I can see many new posibility in SC....greate tool but it have to work same way in manual as in auto(simulation)
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • To get Smart Components to work correct the simulation must be running.
    To run the robot in manual mode you can deselect the robot system from the simulation. See this thread: http://forums.robotstudio.com/forum_posts.asp?TID=4939
    ABB Robotics
  • Klaus
    Klaus ✭✭
    Thumbs UpClap Nice.
    Thanks Anders and tell your boss to give yoou a raise Wink
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • I will Wink
    ABB Robotics
