PC SDK - Setting Program Pointer
i am using VB.net to program with PC SDK.
Sets program pointer to the first instruction of a routine (global or local). |
How do you edit an entire routine?
I managed to change the program pointer by this way (in C#):
control.Logon(UserInfo.DefaultUser);
Mastership master;
master = Mastership.Request(control.Rapid);
Task task;
task = control.Rapid.GetTask("T_ROB1");
task.SetProgramPointer("MainModule", "urunvar");
control.Rapid.Start();
control.Logoff();
this code changes the pointer to the proc named "urunVar". Instead of editing entire routine i wrote a proc to do what i want.
Hope this helps,
Best
In this reply I'm using the "Create a simple PC SDK application" from the PC SDK Application Manual as the base. Its in the "Using the PC SDK" chapter.
So to paste this in you need to follow the basic instruction from there first. You need a Button1 and a Button2 as well.You need a main and a Path_20 proc in the controller, preferably with different actions so that you can see which is run.
Steps;
Start controller
Start app
doubleclick controller
click the buttons[quote]Imports ABB.Robotics
Imports ABB.Robotics.Controllers
Imports ABB.Robotics.Controllers.Discovery
Imports ABB.Robotics.Controllers.RapidDomain
Public Class Form1
Private scanner As NetworkScanner = Nothing
Private controller As Controller = Nothing
Private tasks As Task() = Nothing
Private networkWatcher As NetworkWatcher = Nothing
Public Sub New()' This call is required by the Windows Form Designer.
InitializeComponent()' Add any initialization after the InitializeComponent() call.
Button1.Enabled = False
Button2.Enabled = False
Me.scanner = New NetworkScanner
Me.scanner.Scan()
Dim controllers As ControllerInfoCollection = Me.scanner.Controllers
Dim controllerInfo As ControllerInfo = Nothing
Dim item As ListViewItem
For Each controllerInfo In controllers
item = New ListViewItem(controllerInfo.IPAddress.ToString())
item.SubItems.Add(controllerInfo.Id)
item.SubItems.Add(controllerInfo.Availability.ToString())
item.SubItems.Add(controllerInfo.IsVirtual.ToString())
item.SubItems.Add(controllerInfo.SystemName)
item.SubItems.Add(controllerInfo.Version.ToString())
item.SubItems.Add(controllerInfo.ControllerName)
Me.ListView1.Items.Add(item)
item.Tag = controllerInfo
NextMe.networkWatcher = New NetworkWatcher(Me.scanner.Controllers)
AddHandler Me.networkWatcher.Found, AddressOf Me.HandleFoundEvent
'AddHandler Me.networkWatcher.Lost, AddressOf Me.HandleLostEvent
Me.networkWatcher.EnableRaisingEvents = TrueEnd Sub
Private Sub HandleFoundEvent(ByVal sender As Object, ByVal e As NetworkWatcherEventArgs)
Me.Invoke(New EventHandler(Of NetworkWatcherEventArgs)(AddressOf AddControllerToListView), New [Object]() {Me, e})
End Sub
Private Sub AddControllerToListView(ByVal sender As Object, ByVal e As NetworkWatcherEventArgs)
Dim controllerInfo As ControllerInfo = e.Controller
Dim item As New ListViewItem(controllerInfo.IPAddress.ToString())
Me.listView1.Items.Add(item)
End SubPrivate Sub ListView1_MouseDoubleClick(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles ListView1.MouseDoubleClick
Dim item As ListViewItem = Me.ListView1.SelectedItems(0)
If item.Tag IsNot Nothing Then
Dim controllerInfo As ControllerInfo = DirectCast(item.Tag, ControllerInfo)
Button1.Enabled = True
Button2.Enabled = True
If controllerInfo.Availability = ABB.Robotics.Controllers.Availability.Available Then
If Me.controller IsNot Nothing Then
Me.controller.Logoff()
Me.controller.Dispose()
Me.controller = Nothing
End If
Me.controller = ControllerFactory.CreateFrom(controllerInfo)
Me.controller.Logon(UserInfo.DefaultUser)
Else
MessageBox.Show("Selected controller not available.")
End If
End If
End SubPrivate Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Try
If controller.OperatingMode = ControllerOperatingMode.Auto Then
tasks = controller.Rapid.GetTasks()
Using m As Mastership = Mastership.Request(controller.Rapid)
'Perform operation
tasks(0).SetProgramPointer("Module1", "main")
tasks(0).Start()
End Using
Else
MessageBox.Show("Automatic mode is required to start execution from a remote client.")
End If
Catch ex As System.InvalidOperationException
MessageBox.Show("Mastership is held by another clizaccent." & ex.Message)
Catch ex As System.Exception
MessageBox.Show("Unexpected error occurred: " & ex.Message)
End TryEnd SubPrivate Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Try
'Perform operation
tasks(0).SetProgramPointer("Module1", "Path_20")
tasks(0).Start()
End Using
Else
End If
End TryEnd Sub
End Class[/quote]John
Developer Center0 -
As you can see I'm using this to move the PP and start execution:tasks = controller.Rapid.GetTasks()
'Perform operation
tasks(0).Start()
End UsingJohn
Developer Center0 -
john thank you for the help.this has been a great help, it allowed me to see there was a problem with my system setup.i worked out the problem i had the whole time, when my mentor was trying to fix another problem he reset all my rab libraries back to version 10. This has been behind alot of my other problems.i have now learnt not to listen to my mentor
thank you again for the help and speedy reply.0 -
Hi,John!Maybe there is a problem here.On one controller maybe there are different modules,but it can only be one 'MAIN',and if i want to give a "main routine",i should give it another name,like "main 1""main 2""main 3"... so how can i know the routine name of a module(i want click a button to choose a ".mod"file,and then the vc perform it,so i want the pc get a name by some program)?0
Hi doc-zoo,I am sorry, I have problems understanding what exactly you want in most of your responses, including this one. Maybe it would be easier if you posted code and showed what your issue is?In my example above you can just change the linetasks(0).SetProgramPointer("Module1", "Path_20")
to whichever module and routine you want. So what they are called does not matter.How to load a module using the PC SDK is described in the Application manual"Using the PC SDK - Rapid domain
Working with RAPID modules and programs"How to search for specific procedures is described in"Using the PC SDK - Rapid domain
RAPID symbol search"If you want to know which PROC a .mod file contains before loading it you can just open it like a text file and parse through it to find all PROCs.
John Wiberg2011-09-20 09:17:41John
Developer Center0 -
hi,John!Maybe there is a problem when i expressed myself.The code like this:OpenFileDialog openFileDialog1 = new OpenFileDialog();
openFileDialog1.Filter = "Mod Files (.mod)|*.mod|All Files (*.*)|*.*";
openFileDialog1.FilterIndex = 1;string text1 = openFileDialog1.FileName;if (openFileDialog1.ShowDialog() == DialogResult.OK)
{FileInfo filename = new FileInfo(openFileDialog1.FileName);
string fn = filename.Name;this.master = Mastership.Request(controller.Rapid);...........................tasks(0).SetProgramPointer("Module1", "?????")
tasks(0).Start()}what should i do here"?????"0 -
tasks(0).SetProgramPointer(openFileDialog1.FileName??O"?????")
tasks(0).Start()
WARNING!
The way you do that in your code is VERY dangerous. You allow the user to select ANY procedure, regardless of where the robot arm is. That means that you have no control on what the robot actually will do. The user could even mistakenly select the wrong procedure which could lead to damages and injuries.
You have no way to control which module is loaded and which procedure is selected, I would rethink that design.
WARNING!But I already told you how to do it; Read The Fantastic Manual
[QUOTE=John Wiberg]How to search for specific procedures is described in
RAPID symbol search"[/QUOTE] If you need to know the names of procedures you use the SearchRapidSymbol function.Continuing on the example above, you need to add two listboxes and two more buttons.
Steps;
Start controller
Start app
click button3 to list modules in listbox1
select a module name in listbox1
click button4 to list procedures in listbox2[code] Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
ListBox1.Items.Clear()
Dim sProp As RapidSymbolSearchProperties = RapidSymbolSearchProperties.CreateDefault()
sProp.Types = SymbolTypes.Module
Dim rsCol As RapidSymbol()
rsCol = tasks(0).SearchRapidSymbol(sProp, String.Empty)
If rsCol.Count = 0 Then
ListBox1.Items.Add("Not found")
Return
Else
Dim rs As RapidSymbol
For Each rs In rsCol
ListBox1.Items.Add(rs.Name)
Next
End If
End SubPrivate Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
ListBox2.Items.Clear()
If ListBox1.SelectedItem = "" Then
ListBox2.Items.Add("No module selected in ls1")
Else
sProp.Types = SymbolTypes.Procedure
Dim selModule As ABB.Robotics.Controllers.RapidDomain.Module
selModule = tasks(0).GetModule(ListBox1.SelectedItem.ToString)
rsCol = selModule.SearchRapidSymbol(sProp, String.Empty)
ListBox2.Items.Add("Not found")
Return
Else
ListBox2.Items.Add(rs.Name)
Next
End If
End If
End Sub[/code]John
Developer Center0 -
Please note that in my example above it lists both system modules and program modules. In your code you load a module so then you should take the module name and just list for that directly.John
Developer Center0 -
Hi,John!First thanks a lot for your help ,it helps me a lot!But there is a new problem in my code.when i write the code like this:......tasks[0].SetProgramPointer(listBox1.SelectedItem.ToString(),listBox2.SelectedItem.ToString());
tasks[0].Start();.. ....there`s an erro like this:"SetProgramPointer" is not defined in the"ABB.Robotics.Controllers.RapidDomain.Task"In chinese like this:"?"T?__ 4 ?_oABB.Robotics.Controllers.RapidDomain.Task?__?1??,_?O.?_??_oSetProgramPointer?__?s,?rs?1% F:ABB??-?"<??_? (333) WindowsApplication3WindowsApplication3Form1.cs 733 34 WindowsApplication3<BR>0 -
Look at the top of the code, do you haveusing ABB.Robotics.Controllers.RapidDomain;
Then look at the References, do they have a warning? Are they the correct version?John
Developer Center0 -
I have using ABB.Robotics.Controllers.RapidDomain;
and i have done the References, there are no warning, i don`t know whether they are the correct version.and can you give me the address to download it?My RS is 5.13.010 -
By the way,when i use "Reset Program Pointer ",there is no error .May be i use the wrong version0
Hi,John! Sorry to trouble you again.I have some problems trouble me a lot days.I copy a module and load it,then when i copy another module ,there`s error like:"Event MessageError in T_ROB1-Line6DescriptionGlobal routine name main ambiguous.Data for this message is not saved in any robot controller event log.If acknowledged the message will be removed.ActionsGlobal routine must have names that are unique among all the global types,data,global routines and modules in the entire program .Rename the routine or change the conflicting name."the c# code like this:private void button7_Click(object sender, EventArgs e)
{string localDir = controller.FileSystem.LocalDirectory;
string remoteDir = controller.FileSystem.RemoteDirectory;
controller.FileSystem.RemoteDirectory = remoteDir ;
controller.FileSystem.LocalDirectory = localDir + "/downmod/";
File.Copy(controller.FileSystem.LocalDirectory + "xadd.mod", controller.FileSystem.RemoteDirectory + "xadd.mod", true);......................}private void button4_Click(object sender, EventArgs e)
runxadd();
}public void runxadd()
if (controller.OperatingMode == ControllerOperatingMode.Auto)
tasks = controller.Rapid.GetTasks();
UserAuthorizationSystem uas = controller.AuthenticationSystem;
if (uas.CheckDemandGrant(Grant.LoadRapidProgram))
tasks[0].LoadModuleFromFile(remoteDir + "xadd.mod", RapidLoadMode.Replace);
// RapidSymbolSearchProperties sProp1 = RapidSymbolSearchProperties.CreateDefault();
// sProp1.Types = SymbolTypes.Procedure;
// tasks = controller.Rapid.GetTasks();
//Module selModule1 = tasks[0].GetModule(strmainname);
//RapidSymbol[] rsCol1 = selModule1.SearchRapidSymbol(sProp1, string.Empty);
tasks[0].ResetProgramPointer();
tasks[0].Start();}
//tasks[0].ResetProgramPointer();
// this.master.Dispose();
this.master.Dispose();}0 -
the module code like this:the"Module1.MOD"code like this:MODULE Module1
CONST robtarget p10:=[[524.77,-968.58,952.68],[0.422439,-0.0807052,0.55852,-0.709286],[-1,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget pHome:=[[113.55,-940.17,909.68],[0.394354,-0.0151111,0.0387188,-0.918018],[-1,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget p30:=[[179.47,1049.78,948.14],[0.880088,-0.416906,0.074412,0.214701],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
PROC main()
rInitAll;
rHome;
rMoveRoutine;
WaitTime 0.3;
PROC rHome()
MoveJ pHome, v7000, z50, tool0;
PROC rInitAll()
AccSet 100, 100;
VelSet 100, 5000;
PROC rMoveRoutine()
MoveJ p10, v4000, z50, tool0;
MoveJ p30, v4000, z50, tool0;
ENDPROCENDMODULEthe "xadd.mod"code like this:MODULE MainModule
PROC main()
VAR robtarget rob_tar1;
rob_tar1:=CRobT();
rob_tar1:=Offs(rob_tar1,30,0,0);
MoveL rob_tar1,v1000,z50,tool0;
ENDMODULE0 -
[code]Event MessageError in T_ROB1-Line6DescriptionGlobal routine name main ambiguous.[/code]This just means that in RAPID you are not allowed to have the PROC name "main" more than once. Its a reserved name.Just rename your "main" PROC to something else and you will be fine, since if you use it in two different modules at the same time, then its not really a "main" PROC anyway.John
Developer Center0 -
Because i can only use "ResetProgramPointer()"method that can only reset the pp to the "main",i can`t use the "SetProgramPointer()"method. when i use "SetProgramPointer",there`s always problem i have ask you before.So can you tell me how can i solve it?0
How would the "ResetProgramPointer" function know which main is the true main? This is not a PC SDK issue, its a requirement in RAPID. You can only have one PROC named "main".John
Developer Center0 -
Hi,I have using ABB.Robotics.Controllers.RapidDomain and i have done the References, there are no warning, i don`t know whether they are the correct version.
john20122012-05-21 08:05:590 -
i tried to apply the example obove to start Rapid code. All is working fine but
tasks(0).Start()
takes no effect.
Setting the program pointer works (Visual prof) but Rapid programm is not running. Do i have to change controller settings in RobotStudio?
I am using a virtual controller, is it working at all?
