Error loading RS.13.03 station in 5.14
Klaus
I have a multimove cell that i can't open in RS 5.14.
I get this Exption
RobotStudio .NET exception: Object reference not set to an instance of an object.
Base exception: NullReferenceException
at ABB.Robotics.RobotStudio.Stations.RsTarget.<RobotStudio.API.Internal.IGfxObject.get_Gfx>b__c()
at RobotStudio.API.Internal.GfxData.get_Matrix()
at RobotStudio.Services.Graphics.GfxModel.TraverseGfxTree(IGfxObject gfxObj, Int32 nParent, CBBox<FloatBase>* parentBox)
at RobotStudio.Services.Graphics.GfxModel.Update(Boolean full)
at RobotStudio.API.Internal.GfxUpdater.Update(IApiGfxModel gfxModel, TemporaryGraphicCollection tmpGfx)
at ABB.Robotics.RobotStudio.Stations.Forms.GraphicControl.set_RootObject(ProjectObject value)
at ABBInternal.StationManagement.GraphicWindow..ctor(Project project)
at ABBInternal.StationManagement.GraphicWindow..ctor(Station stn, Int32 nLoadView)
at ABBInternal.FileCommands.FileCommandServices.LaunchStationInGui(Station stn, String defaultStationName)
at ABBInternal.FileCommands.FileCommandServices.OpenStation(String fileName, Boolean loadGeometry)
Get same message if i make a pack&Go in 5.13.03 when i unpack it in 5.14.
Whats wrong
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
I have this problem when I pack in 5.14 and unpack in 5.13.
Klaus: Please contact ABB Denmark for support with your multimove cell.shaz_smach: A Pack and Go created in 5.14 canA't be used in an older version of RobotStudio.Best regards,
ABB Robotics0 -
I willThanks AndersBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
To other white dame problem.I have been told from ABB that it is a Bug in RS 5.14.Hope it will be fixed in 5.14.01Best Regards
Klaus Soenderhegn
ups*....same problemBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 5.5K RobotStudio
- 398 UpFeed
- 19 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 324 IRC5
- 63 OmniCore
- 813 RAPID Programming
- 5 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
