Change workobject in RAPID
Hey there,
i need some help for a function that enables the user to change an existing workobject. Something that uses UIListView in which existing workobject are listed and can be chosen. Then:
[code for GUI that gets new points X1 Y1 and Y2 from user]
temp_frame := DefFrame (X1, X2, Y1 origin:=3);
*chosenworkobject*.uframe:=temp_frame;
In C++ i would use a pointer or something like that to change the existing workobject.
Anyone has a idea how to accomplish that in RAPID?
Many thanks,
Michael
How about a "_currentWorkObject", that you work with in the succeding instructions? I am doing something similar ( using a "virtual" wokobject as the one the instructions are executed in )
I just grabbed something similar from my code - just rotating the oframe using quaterion multiplication...
PROC PivotwobjProgram(orient PivotQuaternion)
wobjProgram := wobjProgramOrig;
wobjProgram.oframe.rot := wobjProgramOrig.oframe.rot * PivotQuaternion;
