System module
I just wonder what kind of program can be in the system module. and what kind of computer language are these programs written in?Is there any one know about this?image
xin
  • Hi Xin,
    As I understand it you can put exactly the the same code into a system module as you can into a program module the difference is how system modules are treated by the controller.
    The following extract is from the Rapid manual:
    System modules are used to define common, system-specific data and routines, such as
    tools. They are not included when a program is saved, meaning that any update made
    to a system module will affect all existing programs currently in, or loaded at a later
    stage into the program memory.
    Hope this helps
  • Thanks a lot Graeme
    xin
