cant delete workobject
wolfino
I have the new RS 5.14. I needed to delete thew workobject i have created but it is not possible it says "failed to delete objects". I have tried a couple more times so now iam having four new workobject but non of them possible to delete. is it a known bug or something?
Please get in touch with your local ABB Service representative that can forward your problem to our tech support.Henrik Berlin
ABB0 -
Did you ever get an answer to why you couldn't delete a wobj? I'm having the same issue. Can you give any advise?phil0
I talked with tech support but they didn't help too much. I finally stumbled on the solution. I had to delete any path that used robtargets in the Wobj's. Sometimes I even had to delete all the paths, even though the targets in some of the paths did not reference the Wobj's I was trying to delete. Didn't work like this in previous versions. Hope they fix this one, it's a pain.phil0
- 40 AppStudio
