RobotStudio Online 5.14 performance to low
Marcel
I have problems with RobotStudio 5.14 when I am Online with a robot. Some times the RobotStudio just doesn't react any more. I watched the Windows Task-Manager and saw that RobotStudio gets some process time but after 10 seconds the process time for RobotStudio goes to 0 for 5 seconds. At that time even scrolling in a program module is not possible. After that 'sleeping' period the scrolling or the inputs will be seen in RobotStudio. My colleague has the same problems, but he has a similar installation on his laptop. Does anybody have similar problems?
Best regards
Marcel
Try to run the attached script. It will re-register some components of the RobotCommunicationRuntime. As an effect, the performance will revert to normal for affected installations. The script will not cause any harm to installations that did not have the problem with the component registration.webwiz/772/Reg_ComServer_NetScan.zip(The script is also available on the RobotWare 5.14 DVD, in the Utility folder).Henrik Berlin
ABB0 -
Hi HenrikThank you for that script. But it didn't help. My RobotStudio still goes sleeping for 5 seconds and is awake for 10 seconds.Best regardsMarcel0
Hi Henrik,I have the same problem and and already runned the script several times with no results.Working online the systems always hangs for a few seconds everytime I apply changes or if I open different modules.Best Regards,Rui0
Same problem as my tropic with slow cursor in the online editor.
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
From version 5.12.x the reaction from RSO is getting worseMentioned it a few times, will investigate this with ABB onsite this week0
Hi <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I stopped now to work with RobotStudio Online 5.14. It is impossible to work online, when the whole computer freezes for 5 seconds, again and again.
I installed RobotStudio 5.13 again. It works perfect, because the robot I am working with has RobotWare 5.10.
But for the next new robot I have no solution yet.
Best regards
Marcel0 -
Same here.I have both 5.13 and 5.14 and only use 5.13 on online controllers.I have a cell VC cell that i upgraded to 5.14 soo have to use it. The offline editor is very slow and yesterday i opened my sell and one off my SC misses 2 line sensors. I had saved it as libery so easy to restore the SC but still a bug.Hopefully we soon get a 5.14.01 with fixesBest Regards
Klaus Soenderhegn
This problem should be solved in RobotStudio 5.14.01, which now is available for download.
http://forums.robotstudio.com/forum_posts.asp?TID=5102Best regards,
ABB Robotics0 -
Here is the problem solved.I face same performense in 5.14.01 as in 5.13.Best Regards
Klaus Soenderhegn
Hi,RobotStudio 5.14.01 + SP1 performance in RapidEditor is still very very slow!Any other solutions?Best regards!0
- 5.5K RobotStudio
- 398 UpFeed
- 19 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 324 IRC5
- 63 OmniCore
- 813 RAPID Programming
- 5 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
