RECORD across different tasks
Hi, how to i define a RECORD which i can access in different tasks?
If not possible, is there a workaround?
Regards.
  • Declare the record in a module in each task.
    Thomas H. Johnston
    PACs Application Engineer
  • Klaus
    Klaus ✭✭
    Declare As PERS and only Init one off them with values
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Create a module and set to multi-task,  after declare what you need it.Tip: Look swuser.sys in spotware use VirtualKey in robotstudio.
