Production Manager fo Milling??
in ScreenMaker
Hi to all,
I'd like to know if is it possible to create a Production Manager like in a weld cell but for a milling cell, using ScreenMaker.
If the answer is yes, I'd like to know how.
Best Regards
Best Regards
hello:ScreenMaker 5.14 comes with pre-defined templates basic, standard, and extended. You can use them to create your screens quickly: in addition to using Production MonitorBest Regards, Srini0
Hello:Production Manager (812-1) can be obtained as an option for any application. You need to customize it per the Application Manual.Best Regards, Jim Proulx
