4 god advices to RD
Klaus
I have 3 god advice to RD.
1. When you Add a new signal in IO on SC4+ you will be told to restart the controller. If you ADD severels you will only be told the first time!!!!!!!
in IRC5 you will be told every time so after add 30 IO on a new controller i'm tired to be told every F... time that the controller need to be restarted....hi come on...you told me 30. times and i got it after the first time
2. I had problems with simulation stops during recording. I have found out why!!!!
If Autosave saves the station during simulation recording it stops...PLZ disable autosave durings simulation and then save station when simulation stops.
3. In RS 4.0 you was able to right click on a taget and in the menu you was able to convert target to Tool or Wobj....PLZ add this again
4. Sometimes the controller loos code after shutting RS and VC down. After faceing this i always create a backup of my controllers every half hour soo i don't lose code.
PLZ add a feather to create autobackup of the controllers when autosave runs.
Still haven't got answer to slow editor!!!!!!!!!
Have i nice weekend all of you
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
