RobotStudio 5.14 hangs when?...
sturner
RobotStudio hangs when when attempting to restart the controller from the FlexPendants prompt message after edditingn an I/O signal.
This will happen when you get the FlexPendant dialogue that suggests the you need to close the flexpendant.
I can reproduce the problem when Re-editing a group output signal in I/O parameters.
Did not see this behaviour on 5.13, this happens on both XP and Win7.
OK... I may have figured this out...The 'FlexPendant Restart Needed' message appears if the I/O simulator is open within studio.At the point you close the pendant, studio hangs... and you will need to use Task Manager to End Studio.
Hi sturner,Please report this kind of problems in our internal ABB tools.Best regards,
ABB Robotics0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
