Help !Command Bar no event action
Please help to check why the command bar menuitem no event action?
I make a command bar and a button,why the command bart menuitem no action?
Thanks /Lister
lister2011-06-22 04:07:37
  • Hello,
    Events should be defined for each menuitem that gets created for CommandBar.
    To add events to the menu item,
    1. In the Properties window, select the menu item from the drop-down list.
    2. Click Events icon and double-click to open the Events Panel.
    3. Click Add Action to add an action/event to the menu item.
    Kindly lets us know if you need more information.
    Thanks
