Create offline system from online
I have a IRB140 robot with a program, points, tools, etc... created.
What i want now is to copy all of that to my pc, and make changes, simulation offline, etc.
I also want to be able to send the changes back to the real robot.
How can i copy an real robot to the virtual robot?
Thanks
Thanks
Ricardo Gomes
http://ricardogomes.eu
HiIf you connect to real robot with your RobotStudio, you can find a Go Offline -button from Online tab. That will create a virtual system from your real robot. Please see more detailed information about Go Offline from RobotStudio Help.-Osku0
Hi.I had problems with the "Go offline" function.My advice is to dreate a backup of the real controller and then create system from backup.That works and takes about 5 min.Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 398 UpFeed
- 20 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 327 IRC5
- 65 OmniCore
- 821 RAPID Programming
- 8 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
